Hi, is it possible to connect to 2 VPNs with Gl.inet stock firmware?
What I would need is to connect to a VPN of one country for certain devices and to the other VPN of another country for other devices.
This feature is currently not supported.
But the feature has been collected and is being evaluated by the PM team.
Thank you.
In an odd way you can I think. In my case I can use the custom routing selection under VPN Dashboard to enable both a Wireguard and Openvpn connection together. I have both options setup on my VPS and there should be no reason it wouldn't work across separate VPS's or paid VPN's. For the routing rules I am not really sure maybe setup a VLAN or something for one and use regular lan for the other? I feel like it shouldn't be too difficult. It wont however run two instances of the same protocol.
A really nice feature would be having the ability to aggregate two VPN's together. Say two Wireguard connections. That would bring the VPN speeds close to maxing the cell bandwidth.
