Dual WAN Load Balance and Wireguard Server
Has anyone found a way to be able to access GL.iNET router/LAN running a WG Server from a remote client when load balancing is on? I don’t even know if this is possible but all works fine as soon as I switch to faileover mode!
It will only work if it’s possible to tie the WG server to one interface. Loadbalance between different WAN interfaces isn’t really what people think :slight_smile:
Thanks for your reply. I take it that there is no easy way to doing this then (thank goodness for Tailscale).
I would assume it should be possible by running the wg server with custom config instead of the GL iNET GUI.
I read a few topics about it. WireGuard itself does not care about interfaces nor IP addresses. You have to use firewall rules for binding it to interfaces.
https://www.reddit.com/r/WireGuard/comments/11zj35r/how_to_bind_wg0_with_eth0/
