Unfortunately, the stick E3372h-320 does not work properly. Everything works on the notebook.
As soon as I connect the “E3372h-320” to the “GL-AXT1800” I can also access the website of the “E3372h-320” for a few minutes and I also get an answer via ping.
However, the network connection is no longer possible after a few minutes. No PING and WebIF from the E3372h-320 (And Internet).
I have also checked different GL-AXT1800 firmware versions.
IP GL-AXT1800: 10.30.40.1
IP E3372h-320: 192.168.8.1
GL-AXT1800
v4.1.0
E3372h-320
V. 11.0.1.1(H697SP4C983)
WEBUI 11.0.1.1(W13SP4C7110)
@alzhao
The Modem (USB ETH Adapter, E3372h-320) will be recognized after plugging in. However,
the “GL-AXT1800” does not get an IP address and the process stops after a while.
Repeatedly trying to establish the “Connect ETH-3” connection is unsuccessful.
There is another problem:
The Mondem (USB ETH Adapter, E3372h-320) is no longer recognized after restarting the “GL-AXT1800” (which is very bad) It is then no longer even possible to establish a connection.
The Mondem (USB ETH Adapter, E3372h-320) must be plugged in again when the “GL-AXT1800” is ready (Booted) otherwise the stick will not be recognized.
These problems do not occur even if I switch a USB 2.0 HUB in between. Then the modem works without a problem. I have now tested it for over 48 hours with a USB 2.0 HUB.
