Easier way to manage users for file shares?
Using Flint.
I’ve got a USB in the router and i’m using LUCI for Network Shares.
I will there was a more intuitive way to manage the users for the shares on the drive.
Does anyone have any easy instructions?
hi,
what is not clear about these instructions?
https://docs.gl-inet.com/en/3/tutorials/file_sharing/#router-settings
Upgrade to firmware 4.x
Then check out the new UI that you can add users
Great stuff.
I did upgrade manually last night to v4 but it ended up factory restting my config too and the WIFI broke. I have to revert firmware and start again.
