I am following the steps here: EasyTether - GL.iNet Docs to set up EasyTether on my Spitz 750 and android phone (paid for Pro version).
I have followed the steps and it looks like tethering is functioning. I can connect another device and do speed tests, access internet, etc.
Question 1: on the router Admin/Internet page there is no indication that Tethering is actually happening. Is this the expected behavior? Or should I see the Tether info active, as when I connect a tethered device manually, through this page?
Question 2: at the bottom of the setup pages referenced in the link above there is a last section ‘Interface Priority’. And it discusses setting these values:
option metric 10
wan
(Ethernet)
option metric 20
wwan
(Wi-Fi Repeater)
option metric 30
easytether
(EasyTether)
To what ‘config interface’ should I add these lines? There are several ‘config interfaces’, and I do see one for easytether →
config interface ‘easytether’
option proto ‘dhcp’
option metric ‘30’
option ifname ‘tap-easytether’
So could someone please clarify the location (which config interface) addition of the option metric values listed in the installation web link above?
Thanks!
