I have my Verizon Wifi jetpack tethered to AR300M. I am wifi connected to the AR300M to access the internet. All works fine. When i try to drag a .ovpn file to the UI i keep getting the error “Cannot find correct ovpn files!”
I have tried both buffered vpn’s .ovpn files and now Nord VPN .ovpn files which are supposed to work according to info Ive found on this site.
What am I doing wrong? Is there another way to install the .ovpn onto the router through terminal?
I am using the GL-AR300M with firmware straight out the box 2.264.
I am using Linux
any help appreciated
heres the tcp.ovpn file… i tried to install the zip and the individual files.
client
dev tun
proto tcp
remote 185.216.34.101 443
resolv-retry infinite
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping 15
ping-restart 0
ping-timer-rem
reneg-sec 0
remote-cert-tls server
#mute 10000
auth-user-pass
comp-lzo
verb 3
pull
fast-io
cipher AES-256-CBC
auth SHA512
