Error when connecting Open VPN
Hi, currently I am trying to connect to the VPN using CyberGhost and Nord VPN, but none of both aren’t working, does anyone can help me to solve this ?
This is my current router Model:
GL-MT3000 Wi-Fi 6 Travel Router (Beryl AX)
I am getting the following error log:
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: TCP/UDP: Preserving recently used remote address: [AF_INET]155.133.15.11:1194
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: Socket Buffers: R=[212992->212992] S=[212992->212992]
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: UDP link local: (not bound)
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: UDP link remote: [AF_INET]155.133.15.11:1194
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: TLS: Initial packet from [AF_INET]155.133.15.11:1194, sid=1ac6b378 b8d45892
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA8
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY KU OK
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: Validating certificate extended key usage
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY EKU OK
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY X509NAME OK: CN=mx100.nordvpn.com
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: VERIFY OK: depth=0, CN=mx100.nordvpn.com
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Sun Oct 15 13:07:47 2023 daemon.notice ovpnclient[6656]: [mx100.nordvpn.com] Peer Connection Initiated with [AF_INET]155.133.15.11:1194
Sun Oct 15 13:07:48 2023 daemon.notice ovpnclient[6656]: SENT CONTROL [mx100.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Sun Oct 15 13:07:53 2023 daemon.notice ovpnclient[6656]: SENT CONTROL [mx100.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Sun Oct 15 13:07:53 2023 daemon.notice ovpnclient[6656]: AUTH: Received control message: AUTH_FAILED
Sun Oct 15 13:07:53 2023 daemon.notice ovpnclient[6656]: SIGTERM[soft,auth-failure] received, process exiting
Sun Oct 15 13:07:53 2023 daemon.notice netifd: ovpnclient (6955): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory```
That a bad useriid/password error.
NordVPN changed its authentication procedure a month or two ago. You no longer use the same credentials as the NordVPN website; instead, you have to set up “Service Credentials” which provides a special userid/pasword for when you manually set up a VPN connection (“manually” as opposed to using an app provided by NordVPN).
Go to the NordVPN website and log into your account. On the left-hand side menu, click on NordVPN (under Services). Scroll down to the bottom of the page and click the “Set up NordVPN manually”. You will then be asked to confirm your identity; you’ll be sent a six-digit code to your email which you will be asked to key in. You will then be taken to Services > NordVPN > Manual setup where you can copy your service credentials which you then use on your router.
