Error while astro relay installing scripts in GL-AXT1800 (4.8.2)
Unknown package 'arc'.
Collected errors:
  • pkg_hash_fetch_best_installation_candidate: Packages for arc found, but incompatible with the arc
  • opkg_install_cmd: Cannot install package arc.
    ash: can't create /etc/astrorelay/arc.cfg: nonexistent directory
    ash: /etc/init.d/arc: not found
Please try replacing the command below:
Original:
curl https://console.astrorelay.com/download/OpenWRT/2102/arc_1.0.0-2102_arm_cortex-a7.ipk -o arc.ipk
Replace with:
curl https://console.astrorelay.com/download/OpenWRT/2305/arc_1.0.0-2305_aarch64_cortex-a53_neon-vfpv4.ipk -o arc.ipk
Alternatively, you can directly select the BE3600 (64-bit) router model.
It should also be compatible with AXT1800 4.8.2.
