Ethernet configuration options not showing up
I just got Flint2 and Slate, and I am trying to set up WireGuard VPN.
Since my family has a main router already, I connected the devices like this;
Home router < Ethernet cable > Flint2 < Ethernet cable > Laptop.
Ethernet configuration options such as Protocol and IP address should show up (Ethernet - GL.iNet Router Docs 4), but it only says "Switch to WAN" or "Switch to LAN".
I need to set this up as soon as possible, because I need to travel overseas next week.
I am a complete novice here, but I will do my best to learn and try.
Any help would be greatly appreciated!
Make sure that you connect WAN port of Flint 2 to LAN port of home router.
Thank you so much!
I did it wrong, I will change it right away.
It solved the problem, thank you again!
I will try from here๐Ÿ™
