ExpressVPN setup on Beryl (GL-MT3000) - Easy to configure?
Hi everyone,
​I am planning to buy the GL.iNet Beryl (GL-MT3000) and I would like to use it with ExpressVPN.
​Before I dive into it, I wanted to ask the community: how easy is it to configure ExpressVPN on this specific router? I know that ExpressVPN doesn't have a dedicated router app for GL.iNet, so I assume I will need to use the OpenVPN manual configuration files.
  • ​Is the setup straightforward via the GL.iNet admin panel?
  • ​Are there any known performance drops or specific tips I should keep in mind?
  • ​Does anyone have a quick guide or a link to a reliable tutorial for this setup?
​Thanks in advance for your help!
Please check OpenVPN Client - GL.iNet Router Docs 4 (for OpenVPN) and WireGuard Client - GL.iNet Router Docs 4 (for WireGuard)
Thank you very much for the answer. Unfortunately, I'm not an expert—can you still confirm if it will work well with ExpressVPN?
Thank you very much
Since I don't use ExpressVPN, I can't confirm nor deny.
As long as ExpressVPN provides WireGuard and/or OpenVPN it should work without any issues.
