If I purchase the GL-AX1800 Flint and it does not provide full coverage in my house, what product or device would I buy from GLI-net that would be compatible as a new WA point or extend the coverage area? Thanks.
For expand wireless coverage areas, most routers are available.
If the range that needs to be covered is not very large, you can buy the travel router.
When you are at home, it as a expand wireless.
When you are traveling, it as the security repeater router.
One router and two purposes.
