Failed to find device
Hello
I bought a GL-B2200 but I can’t detect it (failed to find a device) The repeater tells me that it is connected to my wifi network (both lights are on)but I can’t connect to it either. I had to try to redo all the steps a dozen times from different phones but it still does not work. Can you help me plz :frowning:
If you didn’t use the app to setup then you will have to plug a device into the LAN port and configure the WiFi.
Thx for the tips I think I will try
Not working :((
And btw I’m using the app
I also think that the scan is too fast ( it’s written that it takes a minute but it only takes 5 seconds)
So via Ethernet can you connect to it at 192.168.8.1?
Have you made sure you enabled Bluetooth?
Which page it takes 5 seconds?
or
This is the first picture ( on which we can see the repeater ) and I enable the Bluetooth
If it does not bother, can you just post the image?
No problem but what image do you want ?
