is it possible to do failover in repeater mode with 2 WLANs?
Scenario: WLAN 1 SSID is offline → Switch to WLAN2 until WLAN1 is back?
No sure. Now you can save multiple SSIDs and the router will connect to one available.
If you use a dual band router you can also set up two WISP and assign different metric.
Ah ok this is enough for my setup (connect to one available network from saved ones)
