I need to establish a Failover setup.
Which Gl.iNet routers / devices can do this?
TIA
Barry
All our devices which support more than two WAN connections (WAN1, WAN2, Wi-Fi repeater, tethering, etc.) support WAN failover.
For a more detailed guide on how to configure this feature, you can refer to our official documentation on Multi-WAN: Multi-WAN - GL.iNet Router Docs 4.
Thank you. Which ones are they? TIA, Barry
If you’re looking for a home router solution, the Flint series is a strong choice.
Here are models to consider:
Flint 3 (GL-BE9300) | Tri-band Wi-Fi 7 Home Router - GL.iNet
Flint 2 (GL-MT6000) | High-Performance VPN Router - GL.iNet
GL-AX1800 / Flint - GL.iNet
