Fake/Copy router with smaller RAM?
I buy a Ar150m Router from Amazon.
It use EtronTech EM68B16CWQH-25H SDRAM.
I search datensheet from EtronTech and find that it is only 32Mb.
http://www.etron.com/manager/uploads/EM68B16CWQH_rev1.3.pdf
Do I buy a Fake router?
or maybe the newer version have a smaller RAM?
I don’t know hardware specs. But you should just check how much is the RAM.
ssh to the router and use “free” to check RAM usage.
I think you misread the docs: it is a 32Mx16 … (i.e. 64MB a.k.a 64Mx8 ). All seems copacetic from here!
Best of luck…
