It would be rather handy, given that we can upload many wireguard or openvpn profiles, if there was an ability to visually order the list of them and enable a toggle to try and connect to the first one in the list and if that fails to connect, try the next one and so on.
Thank you very much for your feedback and suggestions.
I think finally we want to implement the failover for multiple VPN instances or tunnel, right?
Probably the v4.8 firmware can meet your needs.
You can upgrade to v4.8.0 beta firmware to experience the Multi Tunnel.
