[Feature request] Add basic ad block to devices which not so powerful to handle ADGH
So... Mainly title.
I think something like adblock-lean (super tiny) or adblock-fast (supports DOH) can be used on devices with limited resources like E750v2 which won't handle ADGH.
While this solutions not so advanced and don't have so much features like ADGH, thay still can block ADs. Which is better than nothing.
P.S: You should also recommend to use SD card for filters storage not to wear-off router's flash.
Thank you for your suggestion. We'll discuss it with the product team.
At the moment, it may be difficult to dedicate additional resources to developing and maintaining a new third-party plugin integration on lower-performance devices.
Our focus will likely be on ensuring that upcoming products have sufficient performance to support ADG Home.
