Is it possible to add support for upgrading the AWG package from version 2.0 to 3.X?
Why this is needed:
Version 3.X includes critical updates, such as HeaderProtectionKey and RandomTrailers, which are necessary for better performance and censorship circumvention. Upgrading manually can break existing configurations, so having an automated or officially supported upgrade path would be highly beneficial.
AmneziaWG 3.x support has already been requested and is under evaluation. Its integration requires firmware and configuration-migration work, and GL.iNet has not confirmed a target firmware version or release schedule.
Until an official upgrade path is available, avoid manually replacing the AmneziaWG 2.x packages on stock firmware, as this may break the GL.iNet VPN interface or existing configurations. Related staff update: Feature Request: Add AmneziaWG v3.0.
Okay, that's good advice for basic users. The issue is that, your most expensive and convenient Travel product like E750v2 (Mudi) is practically useless now because there's no workaround possible even for an advanced user:
AmneziaWG won't work, because the OpenWRT is horribly outdated v22 and related kernel modules are missing
No obfuscation options at all for WireGuard even on Beta software !
Shadowsocks ss-redir is VERY slow
Shadowsocks ss-tunnel for WireGuard is VERY VERY slow
I think you gotta consider why should I buy your product instead of using an open system and OpenWRT support directly.
Please explain what are the next steps for enabling the latest VPN performance and Obfuscation capabilities on E750v2 (Mudi) for travel VPN use-cases.
We understand your frustration, especially after the effort you’ve put into trying different options for travel VPN use. We’re sorry the experience with your Mudi V2 has fallen short of your expectations.
Official AmneziaWG support is being rolled out to supported models from firmware v4.9 onward. The E750/E750V2 currently remain on the v4.3 firmware branch, v4.8 beta branch, which does not include native AWG support.
The Mudi V2’s limited processing power also constrains VPN throughput. Lower speeds are expected with demanding setups, and tunneling VPN through VPN can add further overhead. If you need substantially higher VPN performance, we recommend considering the Mudi 7 (GL-E5800), which offers much greater performance for travel VPN use.
Wow, in the same post you want to sell me again a product that is 2x expensive while failing to address how to keep an expensive device that's not even 1.5 years old useful !!!
I'm quite sure there are at least SOME solutions on E750v2 that could enable WireGuard obfuscation in some cases.
It seems to me now that you do NOT WANT to support it because you want us to upgrade to a 2x expensive model.
BTW. The model you recommend is not shown on the firmware version page, there's no official documentation to confirm it will have a working obfuscation solution. Even in your own reply you omitted any statement about what AWG or WG with obfuscation support.
You magically diverted the focus to VPN throughput and keep talking about performance.
We understand that you are looking for an obfuscation solution for your existing E750V2. To clarify, its current v4.3 stable and v4.8 beta firmware do not include native AmneziaWG support. The AWG support mentioned earlier applies to supported models and firmware versions.
Shadowsocks and third-party AWG packages or installation methods are outside our official support scope. We cannot provide installation, compatibility, or performance troubleshooting for those configurations.
You can check firmware availability for each model on our Firmware Versions page or in the Download Center. The E5800 is currently listed on the firmware page with v4.10.0.
If the E750V2 does not meet your requirements and you purchased it within the past 30 days, please contact support@gl-inet.com with your order details to request a return. Our support team can confirm eligibility and guide you through the process.
