Device: GL-E5800 (Mudi 7)
Target Firmware: Firmware v4.x / Upcoming OpenWrt 25 (op25) Releases
Hi GL.iNet Team & Community,
The Mudi 7 (GL-E5800) is one of the best portable 5G travel routers on the market, especially with its built-in touch display, dual SIM slots, and eSIM management (lpac).
However, one missing piece for mobile power users is true carrier data balance awareness. Currently, local usage tracking (like vnstat) measures raw byte counts at the interface level, but this doesn't account for carrier billing cycles, zero-rated data, or actual prepaid/postpaid account balances reported by the carrier.
The Problem
When managing multiple SIM profiles or automated failover, the router currently relies on local interface counters to guess when a profile is running low. Being able to pull or estimate actual remaining carrier quotas directly on the device would make automated SIM switching and multi-WAN management significantly more accurate.
Suggested Implementation / Feature Request
Modular Scriptable Hooks for Data Allowance:
Provide a designated background hook in the GL.iNet SDK (/etc/gl-cellular/ or via ubus) where users can execute custom lightweight scripts. This would allow users to:
Query carrier balance endpoints (or parse inbound balance SMS/USSD via ModemManager AT/SMS commands).
Inject a standardized JSON output into the router's internal state engine (e.g., {"profile": "sim1", "remaining_gb": 12.5}).
UI & Touchscreen Integration:
Feed this data into the Mudi 7 Touchscreen UI alongside existing signal and interface stats, displaying remaining carrier data instead of just raw interface uptime/counters.
Expose a simple state variable in the GL.iNet Admin Web Panel for quick monitoring.
Multi-WAN & Failover Hook:
Allow the internal SIM failover logic to trigger a profile switch (SIM1 -> eSIM -> SIM2) when a custom data allowance threshold is reached, rather than waiting for complete signal loss or manual intervention.
Having a flexible hook or basic framework for balance reporting would make the Mudi 7 an even stronger tool for international travel and multi-SIM setups.
Would love to hear the team's thoughts on whether scriptable API hooks for cellular balance could be considered for future firmware builds or SDK updates!
Thanks,
LexicDarkA7
