Feature Request Multi-WAN PBR
Multi-wan Loadbalance
The ability to assign a VPN/WG a WAN interface when you are running load balancing.
Reason: It is very common to use one connection for VPN out and another for open web. I use cellular for Streaming and Starlink for all other. Having the ability to assign a VPN a WAN out when in load balance would be VERY nice for many things. Even per device assign WAN would work when multi wan is enabled
Thank you for the suggestion.
We will discuss this with the product team.
In the meantime, you may consider installing the third-party plugin luci-app-pbr to achieve this functionality.
Alternatively, you can also configure the relevant routing table entries manually if you are comfortable working with the command line or Luci.
