I’d really like to be able to change the screen resolution directly from the KVM display, using some preset options.
My use case is simple: at home I use a very wide monitor (2560x1080), but when I access my PC through the KVM from other computers, I usually change the resolution to fit the screen I’m currently using.
The problem is that when I come back home and use the PC locally again, I have to go back into the display settings and manually set the resolution back to 2560x1080.
It would be much more convenient if I could switch between preset resolutions directly from the KVM screen.
Hi, I know I can do it from here, but when I’m working directly from my laptop at home, I don’t want to have to connect to the web UI every time to change this parameter. That’s why I’m asking whether it would be possible to do it quickly through the KVM touch screen.
When I access it remotely, I often change the resolution through the UI to match the screen I’m connecting from. But when I come back home and use Laptop A, I’d like to be able to quickly switch it back to its original resolution.
Home setup: Laptop A -> KVM -> Ultrawide screen (2560 x 1080)
Remote setup: Remote laptop -> UI -> change resolution to fit remote screen
Back home: Laptop A -> KVM -> back to native resolution (2560 x 1080)
