After experimenting with my Mifi for some days and having to reset it now and then due to mistakes, i really miss the save and restore config that the Asus routers have.
I would love to see this in the GL-iNet interface, being able to dump all the settings and restore them when needed.
Actually you can do this in Luci now.
So the Gl-iNet interface is only changing the same files as Luci?
To be precise, both GL UI and Luci use the UCI which is the files in /etc to configure the router. So if you back up using luci it is totally OK.
