Feature Request - Separate Windows and reordering tabs for GLKVM
Adding the ability to split each KVM into it's own window on MacOS would be very appreciated.
Something I would love to see is the ability to have a window per KVM.
As it currently stands, every opened KVM is stacked into a tab on one window.
Furthermore organizing the tabs is currently not possible, so the tabs are ordered from left to right in the order they were opened.
(The ability to reorder them would also be appreciated)
The benefit of this, especially in MacOS would be to make each their own virtual desktop
This setup can also work in Microsoft Windows 8+ systems as well, but not as easily.
It would make managing multiple KVMs at a single time much easier than it is now.
My current solution is to use a browser and have each one open a dedicated instance as a browser window. But the downside of that is I loose functionality, like spamming the esc key on the KVM computer, since that escapes the window control in the browser, where in the app it does not.
I am guessing this is currently not possible due to how the input capture works in the app, but if it can be solved, it would be a fantastic addition.
This is already on our roadmap,separate windows do improve the experience when you have multiple device.And as for the shortcuts, the desktop app can block more shortcuts than the browser. To ehance this ability, we will support almost all shortcuts (like Win key) in the upcoming version which is 1.10(KVM SDK Version).
It isn't nessessarily shortcuts that is the issue, it is keystrokes
