Feature Request: Static IP with Wireless for Comet Pro
Just got Comet Pro. Great device. But one major fault is that I can’t set Static IP information if using Wireless. I can via Wired though. But really do need to have this capability via wireless connection.
DHCP isn’t everywhere and you may not control it as well.
Is this coming in a firmware update? Do need to file a feature request ?
Since this is using Connman this can be easily achieved. All that is needed is the WebUI to expose the settings. Though under the covers it just needs to add settings to the wifi**psk file and note wifi**psk.conf in /etc/kvmd/user/connman/
Example:
Thank you for your suggestion.
We've identified this issue and are actively working on a solution.
