Hi, i would like to use the openvpn client without masquerading. When i deactivate the masquerade checkbox in the advanced->firewall settings, the checkbox is marked again after the router reboots. It seems to me as if the gl-inet gui brings back that setting and maybe takes the setting from some kind of template.
How can i deactivate that permanently?
It is an AR300m with the 2.263 release.
Thanks
