alzhao
November 7, 2015, 1:48pm
The firmware can be download from GL.iNet download center
There is a bug. When you install packages using the WebUI, it always says “return 255” error. But it works find in shell.
Does anybody use the SSH proxy function? Instructions can be found here: 404 Page not found - GL.iNet
kakadu
November 8, 2015, 4:37pm
2
In new firmware i cant install any packages, because links to distribution feeds are broken. Headache with a downgrading and the setting is that what I need right now. Thx guys, great update.
alzhao
November 9, 2015, 11:23am
3
Now the links are repaired. Pls try again.
rene
December 19, 2015, 3:45pm
5
First you need the image for your router
cd /tmp
wget GL.iNet download center
( This is for 6416 if u need the gl-ar150 image use this link:GL.iNet download center )
sysupgrade -v openwrt-6416-2.14.bin
OR sysupgrade -v openwrt-ar150-2.13.bin for the gl-ar150
For more details take a look here OpenWrt OS upgrade procedure (LuCI or sysupgrade) [Old OpenWrt Wiki]
