ah, its ok, i compile it!
@kyson-lok - i create the image using gl_image script. i just update the files-tor-ar/etc/opkg/distfeeds.conf to the 2.27 repo and recompile.
Is it working OK?
Could you make the firmware available (I do not want to test the compilation on a working router). Does anyone else find it strange that firmware for a consumer device has to be compiled before use?
It work, but with some errors on dmesg output, i will try to fix them
