Hi.
When you boot for the first time, connect to wifi with password goodlife
and enter web interface, you have to set a new password.
Before setting a new password, i can connect to ssh but can’t enter a valid password.
Once the new password is set in webui, i can connect to ssh successfully.
How can I connect to SSH before setting a new password in the webui? Is there any password set?
I need to login automatically with a script once the router gets an IP with DHCP.
Thanks.
alzhao
2
I think you can just press enter and get in ssh, no?
I don’t remember if I tried that, i’m going to check right now.
Yes, i tried, but “Access denied” with blank password.
Nor does goodlife
work.
alzhao
5
You have to tell me which model and firmware.
I just tried latest firmware and it is OK to login via ssh without password.
It’s GL-S1300 bought 4 months ago, i think Last version but can’t check now.
It’s GL-S1300 v3.105 although version 3.203 it’s available
Version 3.203 has the same result, i cannot enter into SSH without changing the password from the WebUI. neither blank nor goodlife
are valid.
alzhao
9
can you use telnet? In old openwrt version it use telnet
It works.
Once connected by telnet, it says “Use ‘passwd’ to set your login password!”, so i think ‘root’ does not has password set.
Thanks.
