Dear team,
Can you please help me with USB cellular modems?
I am going to purchase one of them:
Huawei e3372h-607
Huawei E3276
ZTE M823
Huawei E3372
Is there any support to fix TTL to 64 and switch IMEI on those to bypass ISP block of hotspots?
Beryl AX
bruce
March 18, 2025, 7:10am
2
If USB modem is connected to the GL router through tethering, and want to fix TTL 64, need to set it on modem, or workaround like set TTL to 65 on GL router.
If USB modem is connected to the GL router through cellular, it supported to set TTL to 64.
IMEI must be set for modem and has nothing to do with GL router.
Thanks @bruce !
Does Gl supports built-in modem SD card simultaneously?
I mean in computer upu can use Modems SD as flash drive
bruce
March 24, 2025, 7:56am
5
TBH we have not tested this point.
