Hi, I have a GL-MT3000. I am travelling for the next month in europe. What I would like to do is every time I check-in to a hotel or airbnb is to add the local wifi using the admin password so the GL-MT3000 is acting as a repeater but have a fixed guest password so that all other devices, e.g. laptop, phone, tablet can always use the same fixed password (but not the admin password) to login.
Also will it make any difference if I am using a VPN (PIA)?
The SSID and p/w of the GL-MT3000? I must be missing something because I thought to login to the GL-MT3000 I would need the admin password which I don't want to give to all the other devices.
Thanks for your replies admon. My goal is to take the router with me, enter the new wifi SSID and p/w with each new hotel room or airbnb and not have to change any settings on all the other devices, i.e. they should automatically connect to the GL-MT3000-fec-5G-Guest (including the vpn), or the 2.4G if that is the only SSID connected.
If there is a better way of doing this I would be glad to know it.
You connect the MT3000 to the hotel/airbnb wifi using its repeater function. How that works, you can read here. This is the bit you need to do at each new hotel/airbnb.
You can test/try that function just at home by connection it to your own home wifi.
Both tabs of that "Wireless" are for settings of SSIDs of the router itself. The guest tab being for guest (those will be isolated from each other/cannot see each other on the network and just get internet) and the other tab being just for normal use. You can make 2 networks using the device. This bit can just stay the same at each hotel/airbnb!
