Hello can I flash the Tor Firmware back to AR 150 2.20 firmware from LuCi? even if I am connected via wifi (openwrt 192.168.8.1)? or should I consider something?
Thanks
Thanks
When you are using the Tor firmware, you cannot use the UI when using Tor.
You need to connect to ssid “openwrt” and have normal Internet access in the old Tor firmware.
In the new Tor firmware, you need to move the switch to the right side in order to access the admin page at 192.168.8.1
