Hi all,
First off - quick question, what does the switch on the side do? I cannot find an answer anywhere!
Next, I’m trying to flash my MT300A with the OpenWRT ROM mentioned on this page:
https://wiki.openwrt.org/toh/gl-inet/gl-mt300a#installation
Specifically this one: https://downloads.openwrt.org/snapshots/trunk/ramips/mt7620/openwrt-ramips-mt7620-gl-mt300a-squashfs-sysupgrade.bin
Every time I do it, the router ends up in the following state:
It is routing Internet traffic from the WAN port to LAN port perfectly
Its not broadcasting any wireless signal
I can ping it LAN IP address of 192.168.1.1 but I cannot telnet on to it
Browsing to 192.168.1.1 doesn’t work either
So DHCP is working and so is NAT but very little else.
Anyone got any ideas?
I have reverted back to the stock BIN three times and tried re-flashing the OpenWRT bin but not luck.
Thanks
Bob
