If I set the VPN Dashboard from Global Proxy to Client Mode and tell certain devices to use VPN, it works fine for the devices.
The other devices without VPN also work, but with problems.
Do those who should not use VPN also be assigned or does it work automatically? If it should go automatically, it does not work very well. Often comes to disconnections.
It is here.
In fact, Block Non-VPN Traffic option enable, the router uses a more forcible way of blocking leaks. It doesn’t just block the internet when the client is down.
