with the main difference being there is no update failed message, just the progress bar either doesn’t show up (firefox) or never progresses (chromium). New device btw. The ‘how to get support quickly’ page mentions it’s better to do so from windows, but I only have linux, so I need a solution that works for linux.
Uboot is shown as version 2023.10-rc2. LED indicator shows flashing progress but I guess it’s doing nothing since it stops if I navigate the uboot page back to the start.
I was able to unbrick myself using the recovery steps from openWRT here: Testing to determine if you are a bot! (google openwrt mt6000 recovery if link isnt working) (i had successfully flashed from stock firmware to latest openWRT)
(start device normally, hold reset button and it reflashes to default)
Glad to hear that you managed to recover your Flint 2 using the OpenWrt recovery procedure.
Thank you for sharing the solution and your experience with the community.
