Every time I upgrade the firmware on the Flint 2 (this has happened several times now) I have to manually uninstall watchcat from the plugins menu and reinstall it before it will continue to function.
I need watchcat because my ISP connection will fairly frequently go down in a way that requires restarting the interface or rebooting the router (or rebooting the modem which I handle with a local smart plug running a script).
When I install it, it shows in luci, and every time I reinstall it, it seems to have retained the config from the last time. But as soon as I upgrade the firmware, it disappears from the luci interface and seems to stop working such that my router won’t reboot automatically. It will still show installed on the Flint 2 plugins menu, so I have to go in and uninstall and then reinstall for it to work.
Is there any way to make it retain watchcat?
