Flint 2 (FW 4.11) fails to join Flint 4 as Mesh Subnode over Ethernet backhaul
Hello everyone :waving_hand:
I clean-installed the latest stable 4.11 firmware (OP21) on my Flint 2 (GL-MT6000) (with a full data wipe/reset).
I’m trying to join it as a Mesh subnode to my Flint 4 (GL-BE14000) (acting as Mesh main node) using an Ethernet backhaul, but they fail to detect each other.
Network setup:
  • Flint 4 (Main Mesh Node) ➔ 10G LAN port
  • ➔ SFP+ DAC / 10G link between switches
  • ➔ Unmanaged 2.5G switch (office)
  • ➔ Flint 2 (WAN port)
What I tested & observed:
  • Physical connectivity is fine: when configured as a simple Wi-Fi Access Point (AP mode), everything works seamlessly across the switches.
  • When switching the Flint 2 to Mesh Node mode, neither router detects the other.
  • The Flint 2 reports "No Internet access". However, if I plug my Mac into one of the Flint 2's LAN ports, I get full access to the Internet and to the Flint 4's local subnet.
What am I missing? Does the initial Mesh pairing require a direct cable between the two routers (bypassing switches), or does it need to be paired wirelessly first before plugging in the Ethernet backhaul?
Thanks in advance for your help!
Hi, thank you for the detailed information.
Could you please confirm whether the Flint 4’s “10G LAN port” refers to the RJ45 Ethernet port or the SFP+ port? If you are using the SFP+ port, could you try another Ethernet port configured as LAN and attempt to set up the Mesh network again?
For initial Mesh setup, set the Flint 4 to Main Router and the Flint 2 to Mesh Node, then connect the Flint 4’s RJ45 LAN port directly to the Flint 2’s WAN port; the node should be detected and added automatically.
Once the Mesh network is established, you can move the Flint 2 back to its original location, reconnect it through the switches, and check whether Ethernet backhaul works properly.
Thank you for your understanding and support.
Hello @charles2
The 10G Lan port on the Flint4 is indeed the RJ45 one, not the SFP+.
In my study, I plug the WAN port of Flint2 in a RJ45 wall socket which goes on my basement where a RJ45 wall socket is plug in the 10G RJ45 port on the Flint4.
I previously used (this was my initial setup) my 2,5G Switch (Flint2 WAN connected to 2,5G ethernet port of the switch which have a 10G SFP+ connected to the RJ45 wall socket of my study, but as it wasn't working, I tried without (bypassing) the switch, no more success.
That's exactly what I did : set the Flint4 as Main router, then the Flint2 as Mesh Node. But not directly as my study isn't near the basement :slight_smile: Should I brought the Flint2 jsut near the Flint4 with one only cable ?
I'll try this. But I'm pretty sure I'll have the same problem...
Hi, thank you for the clarification.
Could you upgrade the Flint 4 to Beta 6 with “Keep Settings” unchecked, then configure the Flint 4 as Main Router and the Flint 2 as Mesh Node and try connecting them again?
If the issue persists, could you please check whether a device connected to the Flint 4 can access the Flint 2’s admin panel using its IP address?
Please also export the logs from both routers under SYSTEM → Log while the issue is occurring, before rebooting, and send them to us via private message.
