I’ve recently changed ISP to a FTTH 2.5/1 gbps connection with ISP own router that provides DHCP connection to my Flint 2 using a CAT 8 cable to both 2.5 gbps ports.
To my surprise, Flint 2 never reaches 2.5 gbps download speed.
root@GL-MT6000:~# iperf3 -c speed-cb.dimensione.com -p 5201-5209
Connecting to host speed-cb.dimensione.com, port 5201
[ 5] local 192.168.1.2 port 50888 connected to 185.152.44.54 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 35.4 MBytes 297 Mbits/sec 0 1.95 MBytes
[ 5] 1.00-2.00 sec 115 MBytes 965 Mbits/sec 0 3.70 MBytes
[ 5] 2.00-3.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 3.00-4.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 4.00-5.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 5.00-6.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 6.00-7.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 7.00-8.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 8.00-9.00 sec 118 MBytes 986 Mbits/sec 0 3.70 MBytes
[ 5] 9.00-10.00 sec 116 MBytes 975 Mbits/sec 0 3.70 MBytes
[ 5] 0.00-10.00 sec 1.06 GBytes 914 Mbits/sec 0 sender
[ 5] 0.00-10.02 sec 1.06 GBytes 912 Mbits/sec receiver
iperf Done.
I’ve tried many firmwares (4.8.2, 4.9.0, 4.8.2-op24, 4.9.1-op25, actual one is 4.9.0 13/7 snapshot) and every time connection is capped to 1gbps.
I’ve checked also ethtool
root@GL-MT6000:~# ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 2500Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: external
Auto-negotiation: on
Current message level: 0x000000ff (255)
drv probe link timer ifdown ifup rx_err tx_err
Link detected: yes
and it clearly states that 2.5 gbps connection is negotiated with ISP router.
Futhermore using iperf reverse mode I reach advertised speeds:
root@GL-MT6000:~# iperf3 -c speed-cb.dimensione.com -p 5201-5209 -P 8 -R
Reverse mode, remote host speed-cb.dimensione.com is sending
[ 5] local 192.168.1.2 port 51478 connected to 185.152.44.54 port 5201
[ 7] local 192.168.1.2 port 51488 connected to 185.152.44.54 port 5201
[ 9] local 192.168.1.2 port 51498 connected to 185.152.44.54 port 5201
[ 11] local 192.168.1.2 port 51506 connected to 185.152.44.54 port 5201
[ 13] local 192.168.1.2 port 51522 connected to 185.152.44.54 port 5201
[ 15] local 192.168.1.2 port 51524 connected to 185.152.44.54 port 5201
[ 17] local 192.168.1.2 port 51536 connected to 185.152.44.54 port 5201
[ 19] local 192.168.1.2 port 51552 connected to 185.152.44.54 port 5201
[ 5] 0.00-1.00 sec 20.2 MBytes 170 Mbits/sec
[ 7] 0.00-1.00 sec 24.3 MBytes 204 Mbits/sec
[ 9] 0.00-1.00 sec 26.4 MBytes 221 Mbits/sec
[ 11] 0.00-1.00 sec 17.7 MBytes 148 Mbits/sec
[ 13] 0.00-1.00 sec 34.2 MBytes 287 Mbits/sec
[ 15] 0.00-1.00 sec 24.3 MBytes 204 Mbits/sec
[ 17] 0.00-1.00 sec 22.0 MBytes 184 Mbits/sec
[ 19] 0.00-1.00 sec 28.5 MBytes 239 Mbits/sec
[SUM] 0.00-1.00 sec 198 MBytes 1.66 Gbits/sec
[ 5] 1.00-2.00 sec 24.2 MBytes 203 Mbits/sec
[ 7] 1.00-2.00 sec 28.9 MBytes 243 Mbits/sec
[ 9] 1.00-2.00 sec 27.7 MBytes 232 Mbits/sec
[ 11] 1.00-2.00 sec 20.4 MBytes 171 Mbits/sec
[ 13] 1.00-2.00 sec 46.3 MBytes 389 Mbits/sec
[ 15] 1.00-2.00 sec 25.4 MBytes 213 Mbits/sec
[ 17] 1.00-2.00 sec 24.6 MBytes 206 Mbits/sec
[ 19] 1.00-2.00 sec 35.6 MBytes 298 Mbits/sec
[SUM] 1.00-2.00 sec 233 MBytes 1.95 Gbits/sec
[ 5] 2.00-3.00 sec 28.1 MBytes 236 Mbits/sec
[ 7] 2.00-3.00 sec 31.4 MBytes 264 Mbits/sec
[ 9] 2.00-3.00 sec 35.1 MBytes 295 Mbits/sec
[ 11] 2.00-3.00 sec 23.6 MBytes 198 Mbits/sec
[ 13] 2.00-3.00 sec 42.4 MBytes 356 Mbits/sec
[ 15] 2.00-3.00 sec 28.8 MBytes 242 Mbits/sec
[ 17] 2.00-3.00 sec 26.0 MBytes 218 Mbits/sec
[ 19] 2.00-3.00 sec 32.8 MBytes 276 Mbits/sec
[SUM] 2.00-3.00 sec 248 MBytes 2.08 Gbits/sec
[ 5] 3.00-4.00 sec 28.0 MBytes 234 Mbits/sec
[ 7] 3.00-4.00 sec 28.2 MBytes 236 Mbits/sec
[ 9] 3.00-4.00 sec 26.9 MBytes 225 Mbits/sec
[ 11] 3.00-4.00 sec 25.3 MBytes 212 Mbits/sec
[ 13] 3.00-4.00 sec 33.6 MBytes 281 Mbits/sec
[ 15] 3.00-4.00 sec 33.2 MBytes 279 Mbits/sec
[ 17] 3.00-4.00 sec 30.0 MBytes 251 Mbits/sec
[ 19] 3.00-4.00 sec 30.1 MBytes 252 Mbits/sec
[SUM] 3.00-4.00 sec 235 MBytes 1.97 Gbits/sec
[ 5] 4.00-5.00 sec 25.1 MBytes 211 Mbits/sec
[ 7] 4.00-5.00 sec 25.4 MBytes 213 Mbits/sec
[ 9] 4.00-5.00 sec 25.0 MBytes 210 Mbits/sec
[ 11] 4.00-5.00 sec 24.6 MBytes 206 Mbits/sec
[ 13] 4.00-5.00 sec 29.8 MBytes 250 Mbits/sec
[ 15] 4.00-5.00 sec 30.6 MBytes 257 Mbits/sec
[ 17] 4.00-5.00 sec 25.2 MBytes 212 Mbits/sec
[ 19] 4.00-5.00 sec 27.5 MBytes 231 Mbits/sec
[SUM] 4.00-5.00 sec 213 MBytes 1.79 Gbits/sec
[ 5] 5.00-6.00 sec 23.1 MBytes 194 Mbits/sec
[ 7] 5.00-6.00 sec 26.3 MBytes 220 Mbits/sec
[ 9] 5.00-6.00 sec 33.8 MBytes 283 Mbits/sec
[ 11] 5.00-6.00 sec 27.5 MBytes 230 Mbits/sec
[ 13] 5.00-6.00 sec 31.6 MBytes 265 Mbits/sec
[ 15] 5.00-6.00 sec 33.8 MBytes 283 Mbits/sec
[ 17] 5.00-6.00 sec 28.5 MBytes 239 Mbits/sec
[ 19] 5.00-6.00 sec 28.6 MBytes 240 Mbits/sec
[SUM] 5.00-6.00 sec 233 MBytes 1.96 Gbits/sec
[ 5] 6.00-7.00 sec 23.7 MBytes 198 Mbits/sec
[ 7] 6.00-7.00 sec 25.9 MBytes 217 Mbits/sec
[ 9] 6.00-7.00 sec 32.7 MBytes 275 Mbits/sec
[ 11] 6.00-7.00 sec 25.7 MBytes 216 Mbits/sec
[ 13] 6.00-7.00 sec 33.6 MBytes 282 Mbits/sec
[ 15] 6.00-7.00 sec 33.1 MBytes 278 Mbits/sec
[ 17] 6.00-7.00 sec 27.5 MBytes 231 Mbits/sec
[ 19] 6.00-7.00 sec 27.7 MBytes 232 Mbits/sec
[SUM] 6.00-7.00 sec 230 MBytes 1.93 Gbits/sec
[ 5] 7.00-8.00 sec 24.7 MBytes 207 Mbits/sec
[ 7] 7.00-8.00 sec 26.5 MBytes 222 Mbits/sec
[ 9] 7.00-8.00 sec 32.0 MBytes 268 Mbits/sec
[ 11] 7.00-8.00 sec 27.3 MBytes 229 Mbits/sec
[ 13] 7.00-8.00 sec 34.7 MBytes 291 Mbits/sec
[ 15] 7.00-8.00 sec 32.3 MBytes 271 Mbits/sec
[ 17] 7.00-8.00 sec 27.6 MBytes 232 Mbits/sec
[ 19] 7.00-8.00 sec 23.5 MBytes 197 Mbits/sec
[SUM] 7.00-8.00 sec 229 MBytes 1.92 Gbits/sec
[ 5] 8.00-9.00 sec 26.4 MBytes 222 Mbits/sec
[ 7] 8.00-9.00 sec 26.4 MBytes 221 Mbits/sec
[ 9] 8.00-9.00 sec 31.5 MBytes 265 Mbits/sec
[ 11] 8.00-9.00 sec 26.7 MBytes 224 Mbits/sec
[ 13] 8.00-9.00 sec 36.5 MBytes 306 Mbits/sec
[ 15] 8.00-9.00 sec 31.5 MBytes 264 Mbits/sec
[ 17] 8.00-9.00 sec 25.4 MBytes 213 Mbits/sec
[ 19] 8.00-9.00 sec 24.2 MBytes 203 Mbits/sec
[SUM] 8.00-9.00 sec 229 MBytes 1.92 Gbits/sec
[ 5] 9.00-10.00 sec 26.0 MBytes 218 Mbits/sec
[ 7] 9.00-10.00 sec 24.7 MBytes 208 Mbits/sec
[ 9] 9.00-10.00 sec 31.9 MBytes 268 Mbits/sec
[ 11] 9.00-10.00 sec 25.4 MBytes 213 Mbits/sec
[ 13] 9.00-10.00 sec 36.9 MBytes 310 Mbits/sec
[ 15] 9.00-10.00 sec 31.6 MBytes 265 Mbits/sec
[ 17] 9.00-10.00 sec 22.8 MBytes 192 Mbits/sec
[ 19] 9.00-10.00 sec 27.8 MBytes 233 Mbits/sec
[SUM] 9.00-10.00 sec 227 MBytes 1.91 Gbits/sec
[ 5] 0.00-10.03 sec 254 MBytes 213 Mbits/sec 23472 sender
[ 5] 0.00-10.00 sec 249 MBytes 209 Mbits/sec receiver
[ 7] 0.00-10.03 sec 274 MBytes 229 Mbits/sec 26519 sender
[ 7] 0.00-10.00 sec 268 MBytes 225 Mbits/sec receiver
[ 9] 0.00-10.03 sec 320 MBytes 268 Mbits/sec 27633 sender
[ 9] 0.00-10.00 sec 303 MBytes 254 Mbits/sec receiver
[ 11] 0.00-10.03 sec 250 MBytes 209 Mbits/sec 22852 sender
[ 11] 0.00-10.00 sec 244 MBytes 205 Mbits/sec receiver
[ 13] 0.00-10.03 sec 379 MBytes 317 Mbits/sec 34124 sender
[ 13] 0.00-10.00 sec 360 MBytes 302 Mbits/sec receiver
[ 15] 0.00-10.03 sec 323 MBytes 270 Mbits/sec 29093 sender
[ 15] 0.00-10.00 sec 305 MBytes 256 Mbits/sec receiver
[ 17] 0.00-10.03 sec 267 MBytes 223 Mbits/sec 23765 sender
[ 17] 0.00-10.00 sec 260 MBytes 218 Mbits/sec receiver
[ 19] 0.00-10.03 sec 295 MBytes 247 Mbits/sec 26034 sender
[ 19] 0.00-10.00 sec 286 MBytes 240 Mbits/sec receiver
[SUM] 0.00-10.03 sec 2.31 GBytes 1.98 Gbits/sec 213492 sender
[SUM] 0.00-10.00 sec 2.22 GBytes 1.91 Gbits/sec receiver
iperf Done.
Tested both HW acc on/off, SW acc on/off with no meaningful changes and HTOP doesn’t show any bottlenecks. VPN is active only for a few sites and even when turned off speed is still capped.
I’m asking for help to get my clients reaching advertised internet speeds of my connection.
Thanks
