Flint 2 - is Vlan lan possible?
I dont’ see any possibility to set a Vlan for the lan with GlInet gui.
Is it necessary to use the Luci interface ?
could you explain me how to proceed ?
thanks
Yes, it is.
It strongly depends on your needs, you will need to write down what you need - and you will need to try it out by yourself.
I’d like to create a network for devices like TVs , a network for IoT devices and another for all the other devices.
thanks
Unfortunately, this guide is several years old now and early on, the steps don't line up with the interface.
Try this one
