Summary
Since updating my Flint 2 from 4.8.x to 4.11.0, the Domain-Based VPN Policy no longer
behaves as it did before. Instead of letting non-VPN traffic through, the policy blocks
everything on the LAN that is not in the domain list. "Allow non-VPN traffic" is enabled.
Environment
- Flint 2 (GL-MT6000), firmware 4.11.0
- Flint 1 (GL-AX1800), firmware 4.8.x, acting as WireGuard server
- Flint 2 connects to Flint 1 as a WireGuard client
Configuration on the Flint 2 client side
- VPN Policy Routing > Domain-Based VPN Policy
- "Allow non-VPN traffic" = enabled
- Filtration set to "Specified Domain / IP List"
Actual result
LAN clients of the Flint 2 lose internet access for everything except the domains in the
list, even though "Allow non-VPN traffic" is enabled. WG VPN connection is also
unstable dropping VPN link from time to time.
Expected result
Same as on 4.8.x: traffic to domains in the list goes through the VPN tunnel, all other
traffic goes out over WAN normally, stable VPN tunnel.
Also affected: OpenVPN
The same policy with an OpenVPN client instead of WireGuard does the same thing, and it is
worse. I also lose access to the Flint 2 web UI while the tunnel is up, and can only get it
back by disconnecting the VPN, which I did by pulling the WAN cable.
Not affected:
The reverse direction still works. A Flint 1 client with a Domain-Based VPN Policy pointing
at a WireGuard server on the Flint 2 works fine.
Wed Oct 28 15:19:38 2026 daemon.notice netifd: Interface 'wgclient1' is setting up now
Wed Oct 28 15:19:39 2026 daemon.notice netifd: Interface 'wgclient1' is now up
Wed Oct 28 15:19:39 2026 daemon.notice netifd: Network device 'wgclient1' link is up
Wed Oct 28 15:19:39 2026 daemon.info dnsmasq[32441]: reading /tmp/resolv.conf.d/resolv.conf.wgclient1
Wed Oct 28 15:19:39 2026 daemon.info dnsmasq[32440]: read /tmp/hosts/dhcp.wgclient1 - 8 names
Wed Oct 28 15:19:39 2026 daemon.info dnsmasq[32441]: read /tmp/hosts/dhcp.wgclient1 - 8 names
Wed Oct 28 15:19:39 2026 user.notice firewall: Reloading firewall due to ifup of wgclient1 (wgclient1)
Wed Oct 28 15:19:43 2026 user.notice vpn-failover-watcher: action=exit iface=wgclient1 source=setup-timeout reason=startup-connecting-timeout result=connected
