Flint 2 - QoS / Limits not working after Update
First Hello all
Second i got today router Flint 2 i connect all and i set Qos and limits and all was ok (low bufferbloat and jutter) , but update pop out so i press ok and now jitter jump to unloaded +50ms , download +25 and upload +42ms.
So my question is its possible update broke somethink and if yes can someone told me what firmawre is instaled default
It might be an issue with an update, yeah. But not like "it broke something" more like "due to updates, it's different now"
However, updates might reset settings you did. You should re-check all settings and installed QoS addins, if you installed some.
Yes i know all settings gone , so i follow bufferbloat quide and set all again inqos . What i dont understand when I make test on pc all jitters are over+25ms but when i make on smartphone (wifi 5g to router) all jitters are better( alot better , almost perfect) and speed Down and up almost the same like on pc
