Flint 2 set up with vodafone isp
Hello id like to set up flint 2 as a vpn host behind my vodafone wifi hub THG3000 in the UK. How can i set it up without double nat issues etc. i am asking as i think there are some restriction on these isp routers and also because im not tech savvy. Thanks
What do you mean by VPN host?
Do you have ONT box?
I am using Vodafone UK without hub. Just direct to flint 2 via PPPOE.
Update : Vodafone hub is not full control like router. It is limited. So you need contact Vodafone for getting account PPPOE.
So ive set up my flint 2 and ive set up my wireguard behind my isp router. But my speeds on my original isp router is about 320mbps, then on the flint 2 it goes down to134mbps then when i connect to the flint 2 by wire guard it goes to about 50mbps?
