I recently upgraded my Flint 2 to firmware 4.9.0 and have noticed issues compared to the previous firmware (4.8.3).
WireGuard VPN performance drop
Before upgrading, I consistently achieved around 600 Mbps download and upload through ProtonVPN using WireGuard.
After upgrading to 4.9.0, VPN performance changed significantly:
Download: approximately 250 Mbps
Upload: approximately 400 Mbps
During troubleshooting, I found that disabling Network Acceleration increased download speed to around 390 Mbps, but this is still considerably lower than the ~600 Mbps I achieved before the upgrade.
My setup:
Router: Flint 2 (MT6000)
Firmware: 4.9.0
VPN Provider: ProtonVPN
Protocol: WireGuard
I performed a clean installation of 4.9.0 and did not restore any previous settings or configuration backups.
Also WIFI strength have been noticeably lowered, in a small apartment (3 of 4 strength on wifi, 4 meters from router).
Increased memory usage with AdGuard Home
Before update, memory usage was around 38%.
After update, memory usage increased to around 60%:
HaGeZi Pro++
AdGuard DNS Popup Hosts
HaGeZi Windows/Office Tracker
Local DNS filter list (small)
HaGeZi Threat Intelligence Feeds
This appears noticeably higher than what I experienced on previous firmware versions.
Has anything changed in firmware 4.9.0 that could affect WireGuard throughput or Network Acceleration?
Is the increased memory usage with AdGuard Home expected in 4.9.0?
Are there any recommended settings or optimizations to restore previous VPN performance?
Thank you!
