Flint 3 5GHZ wi fi problems
Came from a flint 2, no probelms at all.
With the 3 my PC wont connect to 5ghz, 2.4ghz is fine, tried it with basic default settings and wi fi password., and with my own wi fi name and password. Tried different channels.
Tried 4.8.3 firmware it shipped with , latest stable firmware and latest snapshot.
All other devices connect fine, phones to 5ghz, 6ghz etc.
Cant get my head around why. Reset all network adapters etc.
My network adapter is a mediatek wi fi 6e mt7922
Flint 3 is just pants!
Hi, thanks for the details.
Could you please try the following settings for the Flint 3’s 5 GHz Wi-Fi?
  1. Set the bandwidth to 80 MHz and the channel to 36, Wi-Fi security to WPA2-PSK, forget the saved network on your PC, and reconnect. If it is already set to WPA2-PSK (AES), proceed to the next test.
  2. Please temporarily set the 5 GHz network to Open (no password) and check whether your PC can connect?
  3. After reproducing the connection failure, please go to SYSTEM → Log → Export Log and send us the router logs via private message, along with the time of the failed attempt.
Thank you for your support and understanding.
How to export logs:
How to send private messages:
