Flint 3: beta 4.8.99 - Same SSID for different frequ works!
Just wanted to report a good surprise. After upgrading to latest beta, I’ve tried to set back all my SSID to the same one, and enabled 802.11r 802.11k & 802.11v
It works very well. No more kernel errors in the log.
Also band steering seems to works well here now.
I have added my old Flint 1 ( with Vanilla OpenWRT ) + FLint 3 using same SSID for 2.4 and 5 ghz. It switch quiet fast when moving in the house.
I’ll try Dawn to see if I can improve it more but for now it’s already pretty good.
The important point is to use WPA2 PSK, no WPA3/WPA2-PSK mixed.
Great! Thanks for sharing that!
The firmware doesn't have band steering but probably because 802.11v, r and k are enabled both on Flint1&3. That's reason why supported the roaming.
