I’ve got a Flint 3, PC connected at 2500Mbps full duplex. WAN connected at 2500Mbps full duplex. Internet connection is 2Gbps (YouFibre You2000, so their website says 1800Mbps).
Using the YouFibre provided router fast.com is giving me 2.3Gbps down and 1.8Gbps up, but every attempt i make with the Flint 3 seems capped at 1Gbps. I had previously used SQM but i’ve made sure to turn that off and even delete the profile from the SQM page but no change there.
Any tips or advice on how i can get the Flint to play ball?
Thanks
