Hello GL.iNet Community and Development Team,
I'm experiencing an unusual Ethernet link negotiation issue with my GL.iNet Flint 3 (GL-BE9300), and I would appreciate some assistance in identifying the cause.
My internet connection is rated at 500Mbps. However, when using the router's dedicated 2.5GbE WAN port (eth0), the Ethernet connection negotiates at only 100Mbps, resulting in actual internet speeds of approximately 90Mbps.
Interestingly, when I move the exact same Ethernet cable from the dedicated WAN port to LAN1 and configure LAN1 as WAN, I immediately achieve approximately 500Mbps.
I have also upgraded the router's firmware from version 4.9.1 to 4.10.1.
The issue was originally diagnosed on firmware 4.9.1. I am investigating whether the same behavior persists following the firmware upgrade.
I suspect this could be related to PHY auto-negotiation, firmware compatibility, or a possible hardware issue affecting the dedicated WAN port.
1. Router and Network Information
| Item | Information |
| Router | GL.iNet Flint 3 (GL-BE9300) |
| Current firmware | 4.10.1 |
| Previous firmware | 4.9.1 |
| Internet plan | 500Mbps |
| Connection type | Ethernet wall socket |
| Default WAN interface | eth0 |
| Default WAN link speed before upgrade | 100Mbps |
| Actual speed via default WAN | Approximately 90Mbps |
| Actual speed via LAN1 as WAN | Approximately 500Mbps |
| VPN | WireGuard |
| Auto-negotiation | Enabled |
2. Description of the Problem
When connecting the Ethernet cable from my wall socket to the router's dedicated WAN port, the following occurs:
The router successfully establishes an internet connection.
The WAN interface negotiates at only 100Mbps.
Internet speed tests reach approximately 90Mbps.
Auto-negotiation is enabled.
Disabling WireGuard VPN does not resolve the 100Mbps link speed limitation.
However, when I connect the same Ethernet cable to LAN1 and configure that port as WAN, the internet speed increases to approximately 500Mbps.
No Ethernet cable replacement, ISP plan change, or upstream equipment modification was necessary.
This behavior suggests that the problem may be related to the dedicated WAN port or its interaction with the upstream Ethernet equipment.
3. SSH Diagnostic Results
The following diagnostic results were collected while investigating the issue.
A. WAN Interface Configuration
Command:
uci show network.wan
Output:
network.wan=interface
network.wan.proto='dhcp'
network.wan.force_link='0'
network.wan.ipv6='1'
network.wan.classlessroute='0'
network.wan.metric='10'
network.wan.device='eth0'
This confirms that eth0 was assigned as the WAN interface during testing.
B. Ethernet Link Negotiation
Command:
ethtool eth0
Relevant output:
Supported ports: [ TP MII ]
Supported link modes:
10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supports auto-negotiation: Yes
Advertised link modes:
1000baseT/Full
2500baseT/Full
Advertised auto-negotiation: Yes
Link partner advertised link modes:
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: external
Auto-negotiation: on
Link detected: yes
One particularly interesting finding is that the upstream link partner advertises only 10/100Mbps capabilities to the dedicated WAN port.
The Flint 3 itself advertises support for up to 2.5Gbps.
Nevertheless, the Ethernet link negotiates at 100Mbps.
What makes this unusual is that the same upstream Ethernet connection and cable deliver approximately 500Mbps through LAN1 configured as WAN.
Could this indicate a compatibility problem between the dedicated WAN PHY and the upstream equipment?
C. Attempt to Restart Auto-Negotiation
I attempted to restart Ethernet auto-negotiation using:
ethtool -r eth0
Output:
Cannot restart autonegotiation: Not supported
It appears that this operation is not supported by the current Ethernet driver.
D. Network Interface Status
Command:
ip -br link
Relevant output:
eth0 UP
eth1 UP
eth1.1 UP
eth1.2 LOWERLAYERDOWN
E. WireGuard VPN Test
Initially, I suspected that the speed reduction might be related to WireGuard VPN.
However, I disabled WireGuard and checked the physical WAN link speed again.
The output remained:
Speed: 100Mb/s
Link detected: yes
Therefore, the 100Mbps Ethernet link negotiation issue does not appear to be caused directly by WireGuard VPN processing.
I also checked the ECM IPv4 frontend stop flag:
cat /sys/kernel/debug/ecm/gl_front_end_ipv4_stop
Output:
0
This indicates that the ECM frontend stop flag was not set, although it does not independently confirm that individual traffic flows were hardware-accelerated.
4. Comparison Between the Dedicated WAN Port and LAN1
| Test | Dedicated WAN (eth0) | LAN1 Configured as WAN |
| Internet service | 500Mbps | 500Mbps |
| Ethernet cable | Same cable | Same cable |
| Wall socket | Same socket | Same socket |
| Internet connectivity | Working | Working |
| Actual internet speed | ~90Mbps | ~500Mbps |
| Performance | Severely limited | Normal |
The most significant observation is that simply switching the Ethernet connection from the dedicated WAN port to LAN1 restores the full expected internet speed.
This suggests that the problem is not simply caused by the ISP's subscribed bandwidth limit.
5. Firmware Information
The issue was originally observed while running firmware version 4.9.1.
I have since upgraded to firmware version 4.10.1.
I am checking whether the firmware upgrade resolves the WAN link negotiation problem.
If the behavior persists on 4.10.1, I would like to determine whether this is a known firmware or PHY compatibility issue.
I would also appreciate clarification on whether any changes to WAN PHY initialization, auto-negotiation, or Energy Efficient Ethernet (EEE) handling were introduced between these firmware versions.
6. Similar Reports from the GL.iNet Community
During my research, I found several discussions that appear potentially relevant.
[1] Flint 3 – Packet Loss on the Dedicated eth0 WAN Port
Another user reported severe packet loss when using the dedicated eth0 WAN interface, while an alternative WAN configuration worked significantly better.
Although the exact symptoms are different, this report suggests that different Ethernet ports on the Flint 3 may behave differently with certain upstream equipment.
[2] Flint 3 WAN Speed Capped at 100Mbps
A user reported that the WAN Ethernet link occasionally dropped from 1Gbps to 100Mbps, with a reboot temporarily restoring the higher speed.
The discussion also raised the possibility of an upstream network termination device or ISP-related issue, so it does not conclusively establish a router hardware defect.
[3] Flint 3 RTL8372 Link Instability and Auto-Negotiation Issues
This report describes an auto-negotiation issue where a 2.5GbE LAN connection initially negotiated at 100Mbps before renegotiating at 2.5Gbps.
The discussion included possible PHY and EEE interoperability issues.
I understand that these reports do not necessarily share the same root cause as my issue, but I believe they may provide useful information for troubleshooting.
7. Possible Causes
Based on my observations, I believe the following possibilities should be investigated:
WAN PHY auto-negotiation compatibility: The dedicated WAN port may have trouble negotiating gigabit speeds with the upstream Ethernet equipment.
Firmware or driver issue: The Ethernet driver or PHY initialization process may be affecting negotiation behavior.
EEE interoperability: Energy Efficient Ethernet settings or compatibility could potentially influence link establishment.
Physical WAN port problem: A hardware defect, damaged contact, or PHY issue could prevent proper gigabit negotiation.
Upstream equipment compatibility: The upstream Ethernet equipment may negotiate differently depending on the connected router port.
I have not yet performed a direct test of the dedicated WAN port against another known-good gigabit Ethernet device, so the precise cause remains unconfirmed.
8. Questions for the GL.iNet Development Team
I would greatly appreciate assistance with the following questions:
Are there any known issues with the GL-BE9300's dedicated 2.5GbE WAN port negotiating at only 100Mbps?
Have there been any changes to the
eth0PHY driver or Ethernet auto-negotiation handling in firmware 4.10.1? -
Why would the upstream equipment advertise only 10/100Mbps to the dedicated WAN port when the same cable and connection can deliver 500Mbps through LAN1?
Is there a supported method to reinitialize the dedicated WAN PHY or trigger link renegotiation without rebooting the router?
Are there any recommended commands to inspect PHY status, EEE configuration, or Ethernet driver errors?
Could this be related to a hardware compatibility issue between the dedicated WAN PHY and certain upstream Ethernet devices?
Would placing an unmanaged gigabit Ethernet switch between the wall socket and the dedicated WAN port be a useful diagnostic test?
If the issue persists on firmware 4.10.1, would GL.iNet recommend additional troubleshooting or hardware inspection?
9. Current Workaround
For now, using LAN1 as the WAN port allows me to achieve approximately 500Mbps, which matches my internet subscription.
However, I would prefer to use the dedicated 2.5GbE WAN port as intended.
I am particularly interested in understanding why the dedicated WAN port negotiates at only 100Mbps while another port works normally under otherwise identical conditions.
If any GL.iNet developers or community members have experienced similar behavior, I would appreciate your advice.
I can provide additional SSH logs, firmware information, or diagnostic results if needed.
Thank you for your assistance!
References
[1] GL.iNet Forum – Flint 3 BE9300: Packet Loss on eth0 WAN
[2] GL.iNet Forum – Flint 3 WAN Speed Capped at 100Mbps
[3] GL.iNet Forum – GL-BE9300 RTL8372 Link Instability
