Thanks. That is a consideration. I do not often reset my routers. It is not hard to configure again it is just the clients might need restarting to get the new IP again(?). Food for thought though.
I now have a better understanding of the Flint 3 and ADG. (and how to unblock Apps in the content filtering - MSFS 2024 was a tricky one to find)
I have now expanded the number of devices on my test network - I have added my streaming devices and TV and Sonos and now blocking 66% of the useless DNS - this is more like it.
(Samsung is always phoning home - I have them blocked - cdn.samsungcloudsolution.com
13,398 requests blocked over the last 24 hours (67.08%) and that is after I have Samsung blocked in the content filtering)
Which blocking is processed first used - is it content filtering and then the leftovers go through ADG, or is it the other way around - ADG and the leftovers go through the content filtering or is it some other process?
Although I do find that ADG is still unstable and will stop resolving DNS from time to time - a reboot fixes this. I have also scheduled a daily router reboot to try and mitigate problems.
Did I say I can't wait for the release of the Flint 4?
On a side note, how well would you expect the Fint 3 to work / be compatible as an access point with the Flint 4 as the Master?
Recommended to prioritize Content Filter before ADG.
They aren't mutually exclusive, so this is simply a matter of your own configuration preferences.
Maybe ADG still has too many DNS filtering rules.
If ADG is not turned on, what is the memory usage? If ADG is turned on, how much is it?
To be precise, I haven't tested the Mesh for the Flint 4 and Flint 3. I will share my impressions as soon as I've had a chance to test them.
I tried out the Flint3 and Slate7 first, and I think they're not bad, but right now in alpha version (cannot share to you), some issues at the experience level need to improve, R&D guys are working hard for this.
ADG update - I have reduced the number of blocked sites and ADG has now settled down and now is reliable although I would still like to have many more block lists. I understand this will improve on the Flint 4.
By way of comparison, ADG running on my RasPi 5 on my other (main) network was blocking 90% of useless DNS / ads at one stage yesterday and we were still able to use the internet. The RasPi ADG or more likely the internet, has now settled down to the normal 70+% blocking and 31ms response time.
Flint ADG is at 65% blocked and 14ms response time - pretty good really. ![]()
I noticed a weird behaviour on my Flint 3 with 2.4ghz band. If i change it to 20/40mhz the cpu usage will go to around 10% and the devices that want to use the 2.4 band will have trouble connecting to it. Changing it back to the default 40mhz fixes the cpu usage, which now hovers aroung 1.5% and the devices connected to the 2.4ghz band have zero issues. This kinda looks like a bug,
It is possible that some of the 2.4GHz WiFi traffic on the Flint 3 is not being offloaded to hardware acceleration, causing the CPU needs to process this data and resulting in slightly higher CPU usage.
But the trouble in connecting to the 2.4GHz WiFi is weird. Please help to try reproducing this issue and send us the logs in GL GUI -> System -> Log.
This is the log from the wireless tab in logs:
# Sanitized Wi-Fi log
# MAC addresses were replaced consistently as STA_CLIENT_01, STA_CLIENT_02, etc.
# RADIUS accounting session IDs and kernel pointer-like soc addresses were masked.
# Original timestamps and technical Wi-Fi/QCA/hostapd messages were preserved.
Tue Jun 30 10:27:39 2026 user.warn kernel: [ 12.822101] loading qca-wifi
Tue Jun 30 10:27:40 2026 kern.err kernel: [ 18.536273] wlan: [5549:I:ANY] =======ol_if_register_wifi3_0==========
Tue Jun 30 10:27:40 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:169) wait wifi config ready...
Tue Jun 30 10:27:40 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:149) wifi0 wait wifi config ready...
Tue Jun 30 10:27:40 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:149) wifi1 wait wifi config ready...
Tue Jun 30 10:27:40 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:149) wifi2 wait wifi config ready...
Tue Jun 30 10:27:40 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:194) load wifi config...
Tue Jun 30 10:27:40 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi0 fail: No such wireless device: wifi0
Tue Jun 30 10:27:42 2026 kern.err kernel: [ 20.974192] wlan: [167:I:ANY] ol_ath_wifi_ssr: SSR event 2 bus_type 1
Tue Jun 30 10:27:43 2026 kern.err kernel: [ 21.649467] wlan: [167:I:ANY] ol_ath_wifi_ssr: SSR event 3 bus_type 1
Tue Jun 30 10:27:43 2026 kern.err kernel: [ 21.658058] wlan: [167:I:ANY] ol_ath_wifi_ssr: Waiting for probe lock
Tue Jun 30 10:27:43 2026 kern.err kernel: [ 21.690037] wlan: [167:I:ANY] ol_ath_wifi_ssr: Starting Driver Probe
Tue Jun 30 10:27:43 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi0 fail: No such wireless device: wifi0
Tue Jun 30 10:27:44 2026 kern.err kernel: [ 22.838678] wlan: [167:I:ANY] __ol_ath_attach: soc(0xMASKED): soc0 pdev: wifi0
Tue Jun 30 10:27:44 2026 kern.debug kernel: [ 22.968714] of_get_named_gpiod_flags: parsed 'led-gpio' property of node '/soc/wifi@c0000000[0]' - status (0)
Tue Jun 30 10:27:44 2026 user.warn kernel: [ 23.179263] ***** Fast boot VAP mode is enabled wifi0 *****
Tue Jun 30 10:27:46 2026 user.warn kernel: [ 24.440882] CALLER: /bin/sh/lib/wifi/launch_vap.shwifi0, PID: 6710 arg: enable wifi0
Tue Jun 30 10:27:46 2026 daemon.notice netifd: wifi0 (7822): WARNING: Variable 'mld' does not exist or is not an array/object
Tue Jun 30 10:27:46 2026 daemon.notice netifd: wifi2 (7827): WARNING: Variable 'mld' does not exist or is not an array/object
Tue Jun 30 10:27:46 2026 daemon.notice netifd: wifi1 (7824): WARNING: Variable 'mld' does not exist or is not an array/object
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: first setup
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: wifi restart by network: wifi0
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: value is nil
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: checking for backhaul STA recovery on device: wifi0
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: device up: wifi0
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: wifi restart by network: wifi1
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: checking for backhaul STA recovery on device: wifi1
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: device up: wifi1
Tue Jun 30 10:27:46 2026 daemon.notice netifd: Wireless device 'wifi0' is now up
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: wifi restart by network: wifi2
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: checking for backhaul STA recovery on device: wifi2
Tue Jun 30 10:27:46 2026 daemon.notice netifd: Wireless device 'wifi1' is now up
Tue Jun 30 10:27:46 2026 user.notice qsdk-wifi: device up: wifi2
Tue Jun 30 10:27:46 2026 daemon.notice netifd: Wireless device 'wifi2' is now up
Tue Jun 30 10:27:46 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi0 fail: nil
Tue Jun 30 10:27:49 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:216) found radio wifi0
Tue Jun 30 10:27:49 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:27:52 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:27:55 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:27:56 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan0 attempt 1
Tue Jun 30 10:27:56 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan1 attempt 1
Tue Jun 30 10:27:56 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan02 attempt 1
Tue Jun 30 10:27:57 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan12 attempt 1
Tue Jun 30 10:27:58 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:28:01 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:28:03 2026 kern.err kernel: [ 41.315974] wlan: [158:I:ANY] ol_ath_wifi_ssr: SSR event 2 bus_type 0
Tue Jun 30 10:28:04 2026 kern.err kernel: [ 42.319437] wlan: [158:I:ANY] ol_ath_wifi_ssr: SSR event 3 bus_type 0
Tue Jun 30 10:28:04 2026 kern.err kernel: [ 42.319475] wlan: [158:I:ANY] ol_ath_wifi_ssr: Waiting for probe lock
Tue Jun 30 10:28:04 2026 kern.err kernel: [ 42.324848] wlan: [158:I:ANY] ol_ath_wifi_ssr: Starting Driver Probe
Tue Jun 30 10:28:34 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: No such wireless device: wifi1
Tue Jun 30 10:28:37 2026 kern.err kernel: [ 45.199626] wlan: [158:I:ANY] __ol_ath_attach: soc(0xMASKED): soc1 pdev: wifi1
Tue Jun 30 10:28:37 2026 kern.err kernel: [ 45.383531] wlan: [158:I:ANY] __ol_ath_attach: soc(0xMASKED): soc1 pdev: wifi2
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan0 attempt 2
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan1 attempt 2
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan2 attempt 1
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan02 attempt 2
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan12 attempt 2
Tue Jun 30 10:28:37 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan22 attempt 1
Tue Jun 30 10:28:37 2026 user.warn kernel: [ 45.752918] ***** Fast boot VAP mode is enabled wifi1 *****
Tue Jun 30 10:28:37 2026 user.warn kernel: [ 45.777483] ***** Fast boot VAP mode is enabled wifi2 *****
Tue Jun 30 10:28:37 2026 daemon.notice procd: /etc/rc.d/S22qcawifi-legacy: sh: 1: unknown operand
Tue Jun 30 10:28:37 2026 user.warn kernel: [ 46.042777] Bringup wifi
Tue Jun 30 10:28:37 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: nil
Tue Jun 30 10:28:39 2026 user.warn kernel: [ 47.660736] CALLER: /bin/sh/lib/wifi/launch_vap.shwifi2, PID: 14956 arg: enable wifi2
Tue Jun 30 10:28:39 2026 user.warn kernel: [ 47.724107] CALLER: /bin/sh/lib/wifi/launch_vap.shwifi1, PID: 14953 arg: enable wifi1
Tue Jun 30 10:28:40 2026 daemon.err gl-repeater[5894]: (repeater-nl80211.lua:1036) iwinfo: get info of wifi1 fail: nil
Tue Jun 30 10:28:43 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:216) found radio wifi1
Tue Jun 30 10:28:43 2026 daemon.info gl-repeater[5894]: (gl-repeater.lua:216) found radio wifi2
Tue Jun 30 10:28:46 2026 daemon.info hostapd: wlan0: IEEE 802.11 driver had channel switch: iface->freq=2462, freq=2462, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=2 (40 MHz), cf1=2452, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:46 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan0 after setup 2 check 9
Tue Jun 30 10:28:47 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan1 attempt 3
Tue Jun 30 10:28:48 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan02 attempt 3
Tue Jun 30 10:28:48 2026 user.notice qsdk-wifi: vap still not in correct state, re-setup: ifname=wlan12 attempt 3
Tue Jun 30 10:28:50 2026 daemon.info hostapd: wlan02: IEEE 802.11 driver had channel switch: iface->freq=2462, freq=2462, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=2 (40 MHz), cf1=2452, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:50 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan02 after setup 3 check 2
Tue Jun 30 10:28:53 2026 daemon.info hostapd: wlan2: IEEE 802.11 driver had channel switch: iface->freq=5975, freq=5975, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=10 (320 MHz), cf1=6105, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:53 2026 daemon.info hostapd: wlan22: IEEE 802.11 driver had channel switch: iface->freq=5975, freq=5975, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=10 (320 MHz), cf1=6105, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:53 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan22 after setup 1 check 14
Tue Jun 30 10:28:53 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan2 after setup 1 check 15
Tue Jun 30 10:28:54 2026 daemon.info hostapd: wlan1: IEEE 802.11 driver had channel switch: iface->freq=5240, freq=5240, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=5 (160 MHz), cf1=5250, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:54 2026 daemon.info hostapd: wlan12: IEEE 802.11 driver had channel switch: iface->freq=5240, freq=5240, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=5 (160 MHz), cf1=5250, cf2=0, puncturing_bitmap=0x0
Tue Jun 30 10:28:54 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan1 after setup 3 check 6
Tue Jun 30 10:28:55 2026 user.notice qsdk-wifi: vap_up confirmed: ifname=wlan12 after setup 3 check 6
Tue Jun 30 10:28:56 2026 daemon.err insmod: module is already loaded - ecm-wifi-plugin
Tue Jun 30 10:28:56 2026 user.warn kernel: [ 65.106174] qca-wifi loaded
Tue Jun 30 10:28:57 2026 user.notice qsdk-wifi: vap confirmation round 1/3 passed: ifname=wlan0
Tue Jun 30 10:29:01 2026 user.notice qsdk-wifi: vap confirmation round 1/3 passed: ifname=wlan02
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 IEEE 802.11: authenticated
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:29:03 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_01 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:29:05 2026 user.notice qsdk-wifi: vap confirmation round 1/3 passed: ifname=wlan1
Tue Jun 30 10:29:05 2026 user.notice qsdk-wifi: vap confirmation round 1/3 passed: ifname=wlan12
Tue Jun 30 10:29:08 2026 user.notice qsdk-wifi: vap confirmation round 2/3 passed: ifname=wlan0
Tue Jun 30 10:29:11 2026 user.notice qsdk-wifi: vap confirmation round 2/3 passed: ifname=wlan02
Tue Jun 30 10:29:14 2026 user.notice qsdk-wifi: vap confirmation round 1/3 passed: ifname=wlan22
Tue Jun 30 10:29:15 2026 user.notice qsdk-wifi: vap confirmation round 2/3 passed: ifname=wlan1
Tue Jun 30 10:29:15 2026 user.notice qsdk-wifi: vap confirmation round 2/3 passed: ifname=wlan12
Tue Jun 30 10:29:18 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan0
Tue Jun 30 10:29:22 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan02
Tue Jun 30 10:29:25 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan1
Tue Jun 30 10:29:26 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan12
Tue Jun 30 10:29:35 2026 user.notice qsdk-wifi: vap confirmation round 2/3 passed: ifname=wlan22
Tue Jun 30 10:29:55 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan22
Tue Jun 30 10:29:56 2026 user.notice qsdk-wifi: vap stable confirmed after 3 rounds: ifname=wlan2
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:29:57 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:30:23 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_03 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 IEEE 802.11: associated (aid 2)
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:31:47 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_04 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:31:54 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:33:45 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:33:45 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:33:45 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:33:46 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:33:46 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:33:46 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:33:46 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:34:16 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 10:34:16 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_05 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 10:34:16 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_05 IEEE 802.11: disassociated
Tue Jun 30 10:34:16 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_05 IEEE 802.11: disassociated
Tue Jun 30 10:43:50 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 IEEE 802.11: authenticated
Tue Jun 30 10:43:50 2026 daemon.info hostapd: wlan1: STA STA_CLIENT_05 IEEE 802.11: disassociated
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 IEEE 802.11: associated (aid 2)
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:43:51 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:46:44 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 10:46:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:46:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:46:46 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:46:46 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:46:46 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:46:46 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:46:46 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:46:55 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 10:46:55 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: associated (aid 2)
Tue Jun 30 10:46:55 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:46:56 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:47:26 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 10:47:29 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 10:49:13 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 10:53:55 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_05 IEEE 802.11: disassociated
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 IEEE 802.11: associated (aid 1)
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:53:56 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_05 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:54:26 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 10:54:26 2026 daemon.info hostapd: wlan12: STA STA_CLIENT_05 IEEE 802.11: disassociated
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: associated (aid 3)
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 10:55:05 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 10:57:42 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: associated (aid 1)
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:01:45 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: associated (aid 3)
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:03:43 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:05:48 2026 daemon.info hostapd: wlan2: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: associated (aid 1)
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:12:53 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 IEEE 802.11: associated (aid 1)
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:13:38 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:16:53 2026 daemon.info hostapd: wlan02: STA STA_CLIENT_06 IEEE 802.11: disassociated
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: associated (aid 2)
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:18:17 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:18:47 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 11:18:50 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: disassociated
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: authenticated
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 IEEE 802.11: associated (aid 1)
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 1/4 msg of 4-Way Handshake
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (2/4 Pairwise)
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: sending 3/4 msg of 4-Way Handshake
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: received EAPOL-Key frame (4/4 Pairwise)
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 RADIUS: starting accounting session SESSION_MASKED
Tue Jun 30 11:19:25 2026 daemon.info hostapd: wlan22: STA STA_CLIENT_02 WPA: pairwise key handshake completed (RSN)
Tue Jun 30 11:19:55 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Tue Jun 30 11:19:58 2026 daemon.info hostapd: wlan0: STA STA_CLIENT_02 IEEE 802.11: disassociated
I have 20/40mhz enabled. CPU usage hovers around 10-12.
having similiar issues after the upgrade. My wifi seems to be running out of resources and disconnects constantly and my wan connection drops intermittely. Seems like the router runs out of resources and then restarts the services. I seem to have alot of errors in the logs related to scripts not running and the country selection is set to Germany or something.
We checked the logs and noticed that the client device appears to be repeatedly switching its authentication between MLO and the regular 2.4 GHz / 5 GHz / 6 GHz Wi-Fi networks. This may introduce additional authentication overhead, which could increase CPU usage.
Could you please help confirm the following?
- Are the MLO network and the regular 2.4 GHz / 5 GHz / 6 GHz Wi-Fi networks currently using the same SSID?
- If so, does changing the MLO SSID to a different one help resolve the issue?
- If the problem still persists, please export the complete router logs and send them to us via private message so that we can investigate further.
Hi, thanks for checking for me. The SSID’s were difference for MLO vs the other 3 bands. I noticed alot of scripting errors aswell, so ended up doing a factory reset which resolved the issue. I suspect it was an upgrade issue ( I had made some vlan changes in Luci previously, which I think conflicted with the IoT gateway update).
