Flint 3 - Set up VPS
I own a Flint 3 wireles router & have a VPS provider that I use with AmneziaVPN Software. I currently have firmware version 4.9 on the Flint 3.
How can I add the VPS settings to the Flint 3 to enable the VPS (Racknerd).
Thanks
You can refer to the Amnezia documentation to export a working configuration file first:
After that, follow the tutorial below to import and use it on the Flint 3:
