Flint 3 w/4.8.99 - Ring Stick Up Pro can't connect with
I’m having issues with my Ring Stick Up Cam Pro connecting to the Flint 3. The cam supports 2.4 and 5ghz, so there should be no issue. I can’t get it to connect to my main SSIDs, so I configured a 2.4g Guest SSID. Still no go. I converted the Guest SSID to OPEN and it connected just fine. It looks like the authentication handshake is failing. The cams worked fine with my old Xfinity router.
Was the Ring Doorbell issue fix implemented in 4.8.99?
I’m getting the following in the log.
Wed Nov 26 20:03:13 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 WPA: sending 1/4 msg of 4-Way Handshake
Wed Nov 26 20:03:13 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 WPA: received EAPOL-Key frame (2/4 Pairwise)
Wed Nov 26 20:03:13 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 WPA: sending 3/4 msg of 4-Way Handshake
Wed Nov 26 20:03:14 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 WPA: sending 3/4 msg of 4-Way Handshake
Wed Nov 26 20:03:15 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 WPA: sending 3/4 msg of 4-Way Handshake
Wed Nov 26 20:03:16 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 IEEE 802.11: disassociated
Wed Nov 26 20:03:32 2025 daemon.info hostapd: wlan1: STA 34:3e:a4:11:22:33 IEEE 802.11: authenticated
Wed Nov 26 20:03:33 2025 daemon.info hostapd: wlan1: STA 34:3e:a4:11:22:33 IEEE 802.11: disassociated
Wed Nov 26 20:03:33 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 IEEE 802.11: authenticated
Wed Nov 26 20:03:33 2025 daemon.info hostapd: wlan0: STA 34:3e:a4:11:22:33 IEEE 802.11: associated (aid 14)
Please try to install v4.8.3 (snapshot) firmware for the Flint3 and check again:
