Hello!,
I noticed there was a really long delay for starting up flint like around 5 minutes.
one of those errors contained:
click here
[ 1.608172] coresight-csr 6001000.csr: CSR initialized
[ 1.615830] of_graph_get_next_endpoint(): no port node found in /soc/cti@6010000
[ 1.620797] of_graph_get_next_endpoint(): no port node found in /soc/cti@6011000
[ 1.628350] of_graph_get_next_endpoint(): no port node found in /soc/cti@6012000
[ 1.635732] of_graph_get_next_endpoint(): no port node found in /soc/cti@6013000
[ 1.643101] of_graph_get_next_endpoint(): no port node found in /soc/cti@6014000
[ 1.650490] of_graph_get_next_endpoint(): no port node found in /soc/cti@6015000
[ 1.657870] of_graph_get_next_endpoint(): no port node found in /soc/cti@6016000
[ 1.665246] of_graph_get_next_endpoint(): no port node found in /soc/cti@6017000
[ 1.672618] of_graph_get_next_endpoint(): no port node found in /soc/cti@6018000
[ 1.680008] of_graph_get_next_endpoint(): no port node found in /soc/cti@6019000
[ 1.687386] of_graph_get_next_endpoint(): no port node found in /soc/cti@601a000
[ 1.694762] of_graph_get_next_endpoint(): no port node found in /soc/cti@601b000
[ 1.702136] of_graph_get_next_endpoint(): no port node found in /soc/cti@601c000
[ 1.709520] of_graph_get_next_endpoint(): no port node found in /soc/cti@601d000
[ 1.716908] of_graph_get_next_endpoint(): no port node found in /soc/cti@601e000
[ 1.724267] of_graph_get_next_endpoint(): no port node found in /soc/cti@601f000
[ 1.731645] of_graph_get_next_endpoint(): no port node found in /soc/cti@6198000
[ 1.739100] of_graph_get_next_endpoint(): no port node found in /soc/cti@6199000
[ 1.746469] of_graph_get_next_endpoint(): no port node found in /soc/cti@619a000
[ 1.753851] of_graph_get_next_endpoint(): no port node found in /soc/cti@619b000
[ 1.761267] of_graph_get_next_endpoint(): no port node found in /soc/cti@610c000
[ 1.768640] sps_register_bam_device : unable to create IPC Logging 0 for bam 0x06064000
[ 1.775805] sps_register_bam_device : unable to create IPC Logging 1 for bam 0x06064000sps_register_bam_device : unable to create IPC Logging 2 for bam 0x06064000
[ 1.791511] sps_register_bam_device : unable to create IPC Logging 3 for bam 0x06064000sps_register_bam_device : unable to create IPC Logging 4 for bam 0x06064000
[ 1.806006] sps:BAM 0x06064000 is registered.<3>[ 1.812684] coresight-tmc 6048000.tmc: TMC REG dump setup failed. ret: -38
[ 1.816914] coresight-tmc 6048000.tmc: TMC initialized
[ 1.823714] coresight-tmc 6047000.tmc: TMC ETF-ETB dump setup failed. ret: -38
[ 1.828765] coresight-tmc 6047000.tmc: TMC REG dump setup failed. ret: -38
[ 1.836118] coresight-tmc 6047000.tmc: TMC initialized
[ 1.843024] coresight-funnel 6041000.funnel: FUNNEL initialized
[ 1.848090] coresight-funnel 6100000.funnel: FUNNEL initialized
[ 1.853899] coresight-funnel 6130000.funnel: FUNNEL initialized
[ 1.859807] coresight-funnel 6120000.funnel: FUNNEL initialized
[ 1.865719] coresight-funnel 61a1000.funnel: FUNNEL initialized
[ 1.871777] coresight-etm4x 619c000.etm: ETM REG dump setup failed. ret -38
[ 1.877645] coresight-etm4x 619c000.etm: ETM 4.0 initialized
[ 1.884461] coresight-etm4x 619d000.etm: ETM REG dump setup failed. ret -38
[ 1.890479] coresight-etm4x 619d000.etm: ETM 4.0 initialized
[ 1.897067] coresight-etm4x 619e000.etm: ETM REG dump setup failed. ret -38
[ 1.903067] coresight-etm4x 619e000.etm: ETM 4.0 initialized
[ 1.909675] coresight-etm4x 619f000.etm: ETM REG dump setup failed. ret -38
[ 1.915673] coresight-etm4x 619f000.etm: ETM 4.0 initialized
[ 1.922238] coresight-replicator-qcom 6046000.replicator: REPLICATOR 1.0 initialized
[ 1.928233] coresight-stm 6002000.stm: STM initialized
[ 1.936568] of_graph_get_next_endpoint(): no port node found in /soc/hwevent@6101000
[ 1.940717] coresight-hwevent 6101000.hwevent: Hardware Event driver initialized
I have upgraded flint without checking the reset settings checkbox.
edit
I forgot to mentoin that I came back after I placed a backup in luci, so perhaps some parts of the log are part of the recovery maybe.
full kernel log:
kernel.zip (11.0 KB)
